09-18-2019, 07:07 PM   #1
Stiff focus ring on 18-135mm WR
I recently got a Pentax DA 18-135mm WR on Ebay, and while everything else is great about it except that the manual focus ring is very stiff to move. It's not so stiff that it gets stuck, but I'm unable to do manual focus effectively with it. Autofocus works great, the lens looks clean, and the stiffness is smooth and consistent across the entire focus throw, so I think the problem is a lack of lubrication on the focus ring rather than dirt or a bent lens body. I'm just not sure whether to return the lens or attempt to get this single problem fixed.
09-18-2019, 08:35 PM   #2
ramseybuckeye's Avatar
It should not be like that, if that was not disclosed you should contact the seller to send it back or adjust the price. It could be some internal damage that could get worse.
09-18-2019, 10:21 PM   #3
Paul the Sunman's Avatar
Can be a loose screw, which will only get worse. Probably easily fixed, but it might be best to return it.
18-135mm, camera, focus, lens, pentax help, photography, troubleshooting, wr
Stiff Focus on WR zoom bigbaz Pentax SLR Lens Discussion 10 09-14-2019 05:59 PM
Pentax K SMC-M 35mm f2.8 focus ring stiff Wbl24cam Pentax SLR Lens Discussion 8 06-10-2019 06:31 AM
Stiff focus ring on a Chinar 135mm 2.8 awscreo Pentax SLR Lens Discussion 4 12-09-2018 05:13 PM
SMC Pentax-M Stiff, Very STIFF Aperture Ring rcolman Pentax SLR Lens Discussion 7 11-26-2018 01:32 PM
Stiff focus ring of my DA 70 Ltd Bui Pentax SLR Lens Discussion 5 02-12-2018 06:43 PM
All times are GMT -7. The time now is 05:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
