09-19-2019, 12:47 AM   #1
joerotheray's Avatar
Catch in focus using Pentax K70
My camera seems to be doing all the right things except shutter release at point of focus.
The procedure I use is as follows:
• Menu c4: Select Catch in focus
• Focus method AF
• Focus mode A.F.S.
• Focus centre weighted.
• Lens 1:1.7 M type 50mm
I assume there are no mode dial restrictions.
I am missing something but what it is has got me beat.
Thank you.
09-19-2019, 01:28 AM - 1 Like   #2
QuoteOriginally posted by joerotheray Quote
• Focus method AF
• Focus mode A.F.S.
Thank you.
I thought it had to be in M mode on the dial, but could be mistaken.
Edit: And back-button focus should be disabled.
09-19-2019, 02:03 AM   #3
•Menu c4: Select Catch in focus
•Focus method AF
•Focus mode A.F.S.
•Focus centre weighted.
•Lens 1:1.7 M type 50mm
Thank you.
Do you see the focus confirmation light illuminate while changing focus?
09-19-2019, 02:03 AM   #4
pschlute's Avatar
• Focus method AF
• Focus mode A.F.S.
Thank you.
Have you enabled aperture ring use in the menu ?
Pressing shutter button ?
ps Centre weighted is the metering mode, nothing to do with focus. With a manual lens the focus point automatically shifts to single centre and cannot be changed.
09-19-2019, 04:16 AM   #5
QuoteOriginally posted by slartibartfast01 Quote
Yes, I do.
---------- Post added 09-19-19 at 04:31 ----------
• Focus method AF
• Focus mode A.F.S.
Thank you.
Problem solved. Thank you all. I enabled aperture ring and tested by turning focus ring. Shutter fired. Now to mount on tripod and do the 'walk into focus' test.
(I forgot to mention that mode dial selection was shutter priority.)
09-19-2019, 04:33 AM   #6
Yes, I do.
The shutter should fire when the focus is confirmed assuming you are fully depressing the shutter continuously. Strange.
Edit. I see you have it working now.
09-19-2019, 05:01 AM   #7
Yes, I do.
Walk in test failed. The shutter release button needs to stop at half depression when preparing for the 'walk in' shot. This does not happen.
09-19-2019, 05:14 AM   #8
pschlute's Avatar
You are misunderstanding "catch in focus" There is no automation involved. You need to hold down the shutter button and keep it pressed until the subject is in focus.
09-19-2019, 05:14 AM   #9
Yes thanks. I realize now for it to work as I want a remote is needed. Expecting the button to stop half way for me wander off and do the test is probably somewhat optimistic.
09-19-2019, 05:15 AM   #10
pschlute's Avatar
Using a manual lens in aperture priority limits the lens to maximum aperture only.
09-19-2019, 08:00 AM   #11
Otis Memorial Pentaxian
The work-around is to use a wired remote control that includes a lock for the release button.
09-24-2019, 06:19 AM   #12
Thanks, I had forgotten about that. I may follow that route.
camera, focus, focus confirmation light, focus using pentax, mode, pentax help, photography, shutter, troubleshooting
Catch in focus, live view doesn't catch Oktyabr Troubleshooting and Beginner Help 4 02-24-2019 12:44 AM
Can't seem to make catch-in-focus work on K70 chaplain143 Troubleshooting and Beginner Help 7 08-25-2018 09:20 PM
Using SMC M lenses on K70 DSLR one_orca4u Pentax SLR Lens Discussion 4 01-04-2018 08:04 AM
Macro Using catch in focus on manual lens with macro extension tubes Blueberrybob Photographic Technique 8 08-01-2015 07:53 AM
Been using Burst mode for the first time, and with Catch in Focus Tighelander Pentax DSLR Discussion 2 06-30-2015 08:38 AM
All times are GMT -7. The time now is 01:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
