Originally posted by Gerbermiester Once the film has been removed from your camera, open up the back of it as if you were going to put a new spool of film in.
From here, you can fire the shutter at several different speeds and verify visually if the shutter is functioning properly.
While this won't fix your camera, it'll give you some insight as to where the problem may lie.
Since you're a new member, and I've never seen your work, please don't be offended if I suggest it may be learning error on your part.
How familiar are you with metering and exposing film? Does the metering reading you get seem to be correct? Have you verified your metering with another light-meter or camera?
I know from experience that the first roll of film I put through a films SLR looked more or less like what you are describing. In my case, it was my own lack of experience when it came to understanding exposure.
Unfortunately it seems the camera will only action with a roll of film loaded. There are some hacks online to trick the camera into firing but i have had no success so far
---------- Post added 10-01-19 at 06:45 PM ----------
No offence taken at all. Im very new to this and won't rule anything out at this stage. I use a light metered prism in camera and have checked against a phone app. My feeling is it is unlikely as the last 10 shots I did was all the same subject sitting on a stool in the same way still only 4 shots on the roll came out. I'm going to do another test today. Thanks heaps for the help I am in love with this camera and the process. I hope I can forge on soon knkwing my whole role will be there.
