Originally posted by Vmax911 Which lens is this?
Thanks vmax9.
All auto lenses eg DA 50mm 1.8.
Also with F 28-80mm.
Even with the vintage Hanimex 28mm f2.8 I still hear the noise.
Thanks
---------- Post added 10-04-19 at 12:19 AM ----------
Originally posted by FozzFoster Welcome to the Forums!
That AF/M selector physically pulls in and out the screw drive on the camera's lens mount.
Try flipping it without a lens attached and see if the screw drive moves with the selector..?
You are absolutely spot on.
The AF/MF switch does not retract the motor drive.
It simply sticks out all the time.
Any solution for this?
Thanks.
---------- Post added 10-04-19 at 12:24 AM ----------
Originally posted by ZombieArmy Is it actually focusing or is it just making a noise?
It actually does focus.
But it was disruptive when I tried to take macro shots.
I have just confirmed that the motor drive permanently sticks out whether the AF switch is on AF or MF.
Just wonder how to fix this.
Thanks for your help.
---------- Post added 10-04-19 at 12:27 AM ----------
Originally posted by grahame I believe it is the SR noise.
Thanks Grahame,
Someone suggested I switch between AF and MF with the lens off and I observed that the motor drive sticks out all the time.
I think that's the problem.
---------- Post added 10-04-19 at 12:34 AM ----------
Originally posted by luftfluss When you move the AF/MF switch to MF, ensure that the switch is completely at the end of its travel to MF, otherwise the camera may still attempt to AF.
Yes, I have made this mistake on a number of occasions.
Thanks luftfluss and kozloc?
I have checked and despite fully flicking the switch the drive end just sticks out.
