Well every day is a school day!
pschlute:
Originally posted by pschlute That is not right. Try a few test shots again. The aperture should stay wide open irrespective of where you place the aperture ring (other than "A") in Av mode. Take a shot at f4 and at f16. what shutter speed and ISO are you getting ?
So a bit of experimenting gave me the following results, all while in AV mode:
Sigma 28 - 90 lens -
ISO selected at 200, Aperture ring on "A"
F5.6 Shutter speed 1000
F16 shutter speed 125
ISO selected at 200, Aperture ring being used
F5.6 shutter speed 1600
F16 shutter speed 1600
Data on each image shows that the 1600 / F4.5 being used for the images which are both exposed normally. Interesting as that would appear to indicate that the selection of the aperture ring in this case is not changing the physical aperture size. In order to use the aperture in AV mode then I need to have the aperture ring set to "A"
Sigma 28 - 90 lens on manual extension tubes (no electrical contacts} -
Shutter speed is dependant on the amount of light entering, but at the aperture is on "A" that will depend on where I point it!
ISO selected at 200, Aperture ring not on "A"
Again shutter speed is dependant on amount of light, however changing the aperture size using the aperture ring will change the amount of light but also the depth of field. This is the mode I use most often when doing macro work, perhaps though I need to be in Manual mode rather than incorrectly using AV mode. Either that or set up a user preset for macro mode, I haven't tried that yet.
stevebrot:
Quote: Exposure compensation is sort of sneaky in that it is easy to forget it has been set and by default, the camera will remember the setting between (on/off) power cycles. After a couple of episodes like yours, I edited the menu settings so that that feature returns to zero when the camera is turned off.
menu --> Record mode 4 --> Memory --> EV Compensation: uncheck
Done that cheers, I had never been in the memory mode menu option before so I might go back and reset a few other things!
