10-09-2019, 08:46 AM   #1
RAW mode
I have a K100D and I can't figure out how to change the setting to RAW, and the manual isn't helping. It says I need to select a certain option on the playback menu palette, but that option isnít there for some reason. A short how-to of the menu to set it would be great. Thanks- Ethan
10-09-2019, 08:55 AM   #2
sergysergy's Avatar
Hi Ethan, it may show as PEF instead of RAW
10-09-2019, 10:39 AM   #3
pschlute's Avatar
QuoteOriginally posted by sergysergy Quote
Both PEF and DNG are simply different variations of raw format.
10-09-2019, 10:57 AM   #4
In the menu find "Quality Level." The options are RAW, ***, **, *. RAW is obviously RAW, Any of the stars (*) are JPEG compression levels, with *** being the lowest compression.
10-09-2019, 11:03 AM - 1 Like   #5
dlh
F.O.G. (fat old geezer)
dlh's Avatar
QuoteOriginally posted by Vmax911 Quote
If I may add for clarity, that the *** JPEGs are compressed the least among all the JPEG options, i.e., this setting will preserve the most data and produce the best image quality.
The raw data is compressed somewhat, but it's a "lossless" form of compression and has no effect on image quality (or so they say).
10-09-2019, 11:42 AM - 1 Like   #6
Lossless compression doesn't reduce image quality, which is why it doesn't reduce image file size a lot.
10-09-2019, 02:54 PM   #7
HDR?
Make sure HDR isn't turned on.
10-09-2019, 03:25 PM   #8
Ex Finn.'s Avatar
QuoteOriginally posted by ethanenella Quote
1. Power up the camera.
2. Press "Menu" button.
3. Using 4 way controller down button scroll down to " Quality Level"
4. Press the four way controller right button, this takes you to the quality settings.
5. Use the 4 way controller up-down buttons to high-light "RAW"
6. Press "OK" button two times.
Now you are in RAW mode, confirm this by pressing the "Info" button. It will indicate the recording quality setting.
10-09-2019, 03:29 PM   #9
Ex Finn.'s Avatar
QuoteOriginally posted by StanC Quote
Unfortunately K100D does not have that option.
10-09-2019, 03:33 PM   #10
Just1MoreDave's Avatar
Probably you can't be in Green mode - the option might show on the screen but it's grayed out and you can't access it. Some or all scene modes might also be similar. They need to create a JPG to create their scene effect.
10-09-2019, 03:50 PM   #11
Ex Finn.'s Avatar
QuoteOriginally posted by Just1MoreDave Quote
The K100D will shoot RAW in the "AUTO PICT" mode.
camera, menu, option, pentax help, photography, troubleshooting
RAW+, K1 mII, HDR raw files jcdoss Digital Processing, Software, and Printing 6 11-26-2018 01:29 PM
Difference between Pentax K1 Raw vs Sony Raw??? kooks Non-Pentax Cameras: Canon, Nikon, etc. 16 05-18-2018 04:26 AM
Raw Therapee Annoying Auto Levelling Raw BruceBanner Digital Processing, Software, and Printing 8 03-25-2018 06:21 PM
RAW+ vs. RAW vs. JPEG StrasburgBarry Pentax K-1 30 01-14-2018 07:27 PM
RAW, Raw, or raw? stewart_photo Pentax DSLR Discussion 10 01-22-2009 07:14 PM
All times are GMT -7. The time now is 09:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
