Originally posted by stevebrot And, as always, any cross-head screws one might find are not Phillips-head. They are JIS cross-head and have both different depth and different angle. Use of a Phillips screwdriver runs the risk of stripping the screw head, though it has been done with no harm.* I might also caution that care should be used when removing the focus grip. It may be brittle with age.
* I have done so, but now that I own a selection of JIS drivers, the difference in fit is obvious.
In my research, I have seen mention of at least 7 different screwdriver tips sizes. I suspect the larger numbers denote
screwdrivers for Japanese motorcycle repair, or similar. What sizes would an infrequent user really need to make adjustments
like mentioned in this thread?
Thanks.
