Originally posted by UncleVanya Steve does that mean switching the lens to manual/M mode on the k1000? I assume the Spotmatic F automatically stops down while the k mount body doesn't.
Yes, an adapted M42 lens must be operated as manual aperture (stopped down) for metering and during exposure when adapted to K-mount; and yes, the Spotmatic F does auto aperture actuation with M42 lenses the same as all other Spotmatic models.
How it all works with SMC lenses is fairly complicated, but the gist is...
- SMC Takumars (A/M switch on lens in A position) on the Spotmatic F behave the same on that camera as Pentax-K on the K-1000, meaning that the combination meters wide open. Having the switch in the M position with an SMC Tak on that camera is technically possible, but not recommended.
- M42 Takumars (SMC included) must be used stopped-down as manual aperture lenses (switch in M position) for both metering and exposure when adapted to a K-mount body. Yes, it was just as cumbersome then as it is now on our dSLRs.
- SMC Takumars on M42 bodies other than the Spotmatic F, Electro Spotmatic, ES, and ESII operate the same as non-SMC Takumars
- Non-SMC Takumars operate the same on the Spotmatic F, Electro Spotmatic, ES, and ESII as on other metered Spotmatic models
