Originally posted by ndzinn Thanks. Which camera are you using? My concern about center focus is that birds seem to move faster than I can follow with just one focus point, but I'll try again. Any thoughts about using the 55-300 PLM with the Pentax 1.4x TC? Less IQ, I guess, but still rapid autofocus?
Well, I shoot college-level roller hockey using center spot AF with good results. Of course much depends on your own capabilities. Practice does make a difference.
---------- Post added 10-21-19 at 01:37 PM ----------
Originally posted by csa Sandy, great results under extreme lighting conditions! You're photos are starting to sway me towards a KP!
Yes, Indeed! Very impressive. If I start having frequent needs beyond 300mm, I will be considering the DFA 150-450mm myself. I've had a Sigma 150-500mm for years, which I bought used locally in perfect condition, but I've wound up not using it very often. On occasions where I have used it, results seemed quite good. I have no doubt of the DFA lens's superiority, but with infrequent use, the cost is a factor, since I do have the range already covered with decent quality.
