Originally posted by photogem Shipping costs are pretty expensive from UK to USA.
And it is true, no batteries are allowed, could be that on customs they check and send it back or whatever.
It was a bad idea to buy it from USA just due to the fact that if problems arise, one can't do much or it is pretty expensive.
For $ 40 you can buy the white solenoid and built it in yourself.
Read the
manual I wrote , it is straight forward.
And then get this amount back from the seller.
This is how a Solenoid-hungry:
K500 sells for in the USA
If you got it with a DA-L 55-300 lens, this sells cheap as well.
If you can find an *ist, K100D or similar you might find the solenoid cheap
Thank you but there is no way I am going to try and fix it, I managed to junk my 80-320mm lens trying to clean it inside and that has scarred me and acknowledges my D-I-Y skill level as very very poor.
---------- Post added 10-30-19 at 08:15 AM ----------
---------- Post added 10-30-19 at 08:17 AM ----------
Thank you all again, the seller and I have agreed an equitable Ģ50 refund and I may retain the body and use it specifically for manual lens use.
Maybe I will sell it on at a later date.
