Originally posted by MossyRocks I don't know that lens not owning one but it looks like it has some coma in the first shot. Isn't the front element on that lens fairly large and isn't it fairly heafty as well? If so that may be like my 400/2.8 where it has issues in the punishing case of astrophotography until it reaches thermal equilibrium. My big lens takes close to 2 hours because it is so heavy but I would think letting your 15mm sit for a half an hour and it would probably be good since it has a lot less mass. With my 400 the coma goes away completely however I'm not sure if that will work with an ultra wide since there seems to always be distortion in the corners and I would assume that this image is the corner one. Does the coma look the same in all the corners or is different as that will tell you if the lens is
decentered. If it is decentered then it should be sent back to get one that isn't.
As far as the purple fringing it could be from a missed focus but is just as likely to be the lens design. With a lens like this you cant use a bahtinov mask to get that perfect focus so you will have to do star minimization. Put your camera into magnified live view with a star in the center of the frame. Be sure to have focus peaking OFF as it will bloat the star so it becomes hard to tell when you have the smallest possible star. Then get the star as small as you can. You should be really close to a perfect focus. I never trust the infinity mark on my lenses. If that doesn't resolve the purple fringing then you will have to stop the lens down. Some otherwise great lenses do this with astrophotography which seems to show every issue a lens has. The DFA 100/2.8 macro is a purple fringing monster with astro shots, as is the 135/2.3 Vivitar Series 1 even though they are great lenses in normal circumstances.
Thank you for all the replies, as for the focusing, I am using max magnification and live view, with no peaking, the images above are the best results I could obtain, turning focus ring even slightly either ways makes the distant objects more blurry/fringing intensifies. The image does become acceptable around 3.5, it just kind of defeats the purpose of having f2.4 hence why I was hoping for input from other users of this lens. I used to have a Samyang 10mm 2.8 on APSC body and the stars were perfectly in focus with no color fringing even at f2.8. About what "MossyRocks" said, there might be something about the size of the front element, it is indeed much bigger compared to the mentioned samyang. About thermal equilibrum or such, I have a Blackstone version (full metal), so I imagine it should reach it pretty fast.
