Originally posted by Penview52 Impression of the photos: From F2.8 to F6.3 the photo is bad, From F11 to F20 is acceptable. Aperture priority is not only the bases of testing that the lens is bad. Explore P, Scn, and Auto mode if it makes the difference.
How can make a difference once P, or SCN or TAV gives the same three exposures factors (Time, ISO and aperture) then AV mode? AUTO is generating JPG so it's adding software process that could mask the defect
Thanks
---------- Post added 11-09-19 at 02:46 AM ----------
Originally posted by Its Y I shoot Pentax I would see if you could try another copy. There is something off on the lens. about the only other variable is looking at how the lens shoots at different focal lengths.
Unfortunately at different focal lenghts the problem is still the same and, more important, I check old photos I did , at f2.8, in the past and there was no such a massive jam.
Thanks
Danilo
---------- Post added 11-09-19 at 02:53 AM ----------
Originally posted by mikesbike It is possible the lens has been defective right from the time you got it, but have not noticed until now. When shooting at a smaller aperture, in this case as small as f/20, the increased depth-of-field (DOF) renders much more in the frame to be sharper, which hides the problem. When shooting at wider apertures like f/2.8 the lack of sharpness on the left side shows up- that is if your camera is evenly at right angle to the building on both the camera's right and left side, that is- this is not an angled shot. This result as shown suggests a decentered lens.
Here's another way to test for this: Use a tripod, set SR to "off". Use center-only spot AF. Shoot again at 200mm, and set at f/2.8 aperture. Find a somewhat distant solid subject having well-defined edges and some well-defined detail. It should be well within the frame, so it appears on the small size within and not at all filling the frame. Now, using your spot AF, carefully achieve accurate sharp focus with the object in the center. Then carefully switch the camera (and lens?) to MF so as not to disturb focus. Take a shot to see if you've got sharp focus with the object in the center of the frame. If so, re-orient your camera on the tripod (panning, etc), taking care not to disturb the lens's focus, placing the object near each edge of the frame, right, left, top, bottom, even near each corner, and do a shot at each position, leaving focus set to MF. If there is a clearly noticeable discrepancy in lack of sharpness at any edge over the other edges, this indicates a decentered lens.
I did it . And the problem is exactly that one. I did not try to put the object on the top and on the bottom of the frame but I can try again. 220€ to repair it is not too much generally speaking but too much for me and for the use I do
Thanks
(I'll try, btw )
