Originally posted by R.Miller Sad you make assumptions and inferences about my skill level with no objective evidence.
This is about giving prober advice to those who ask important questions.
But to bring it more to a point:
WD40 can be used if you use a tiny amount and use it as a cleaner, then clean again with alcool.
It is powerfull stuff for rusty screws, bice-chains (there only if cleaned again, because the residue after evaporation is sticky and bad for moving parts)
In almost all audio- studiotechnic- electricguitar- and similar forums it is warned "Beware of WD40!"
So actually I was very friendly in my response.
But you just want to stick with it (and yes, WD40 is sticky after a while)
Originally posted by R.Miller The value of having someone do a repair at a shop is determined by the one having the work done. Not you.
C'mon... the repaircosts for a K-r would be at least US$ 150.
We don't have to discuss this!
Originally posted by R.Miller I'm done with this thread and will no longer respond to your petty little attacks. I hope you enjoyed yourself.
Not attacks at all. Putting errors straight! That's all.
There should be a strict warning:
!!! NEVER US WD-40 on contacts of a Pentax if you are not able to right away clean it off !!!
Advice given to just spray it inside your camera is wrong as wrong can be!
Of course: We are speaking of THE WD40 you recommended, not the new WD40 contact cleaner.
