3 Days Ago   #1
Ricoh R1E flash and turning off weirdness
Cannot figure this out.
My Ricoh R1E, which I've recently started using again after nearly 20 years has been great for a few months but has suddenly started turning itself off after every shot. Like turning it's own power off, lens retracting back in etc.
On top of this it doesn't flash either. Not in any of the flash modes. But it does, however, if you set it to red eye flash mode, actually fire the red eye flashes but not the main one with the shutter.
Just done some more tests and it appears the shutter isn't opening. I think that's why it doesn't flash and turns itself off as a warning. I suppose that's clever but how do I stop the shutter not opening?
I can't even work out how to keep the camera on with the back open to do a bit more testing. Any ideas on that either?
Any ideas? I could bin it but I love this thing!
3 Days Ago   #2
I’d check for a fresh battery first...
You may be able to convince the camera that the door is shut. Check to see if there is a prong on the door that pokes into a hole in the camera body. If so, there’s probably a metal plate in the hole. A shaft of the right diameter (like that of a cotton swab) might fit in there to depress the plate and make the camera think the door is closed.
But I still think you have a bad battery
-Eric
3 Days Ago   #3
Not a Number's Avatar
Check to see if the battery contacts are clean.
With electronic equipment that has been unused for 20 years or so it is likely a capacitor or two may have leaked or dried out. Same with the lubrication. If there are timing gears and they aren't moving properly the timing and operation of functions will be off or fail altogether.
3 Days Ago   #4
Thanks both. I have worked out the door thingy now and can confirm from the back also that the shutter isn't opening. I've also put in a new high quality battery and no difference. It's annoying that having sat in a cupboard for 15 years it worked fine but now I've been using it a few months it's stopped.
3 Days Ago   #5
35mmfilmfan's Avatar
If you've not used it in 20 years, it is hardly a surprise that various components have packed up. Time for a bit of R & R (Retire and Replace).
camera, eye, flash, ideas, pentax help, photography, ricoh, ricoh r1e flash, shutter, troubleshooting
K1 & flash AF360FGZ - how to disconnect the flash for 1shot without turning it off ? elodieidj Pentax Full Frame 38 02-16-2017 04:30 AM
K-mount Ricoh kr-30sp light meter weirdness barchaetone Troubleshooting and Beginner Help 8 07-07-2016 09:19 PM
Turning off built-in flash when using AF540 on K10D Reconman-1033 Troubleshooting and Beginner Help 5 01-14-2010 12:52 PM
Turning off flash on K200D luzianne Pentax DSLR Discussion 5 07-05-2008 09:45 PM
Flash Question - Turning Off Flash Quickly For a Shot sweetpapa Pentax DSLR Discussion 5 06-16-2008 12:04 AM
All times are GMT -7. The time now is 09:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
