Originally posted by ecostigny
The link to the SMC Pentax-FA 50mm F1.4 is the same as the link to the HD Pentax-D FA* 50mm F.14 SDM AW.
If the original poster had picked up an M lens, we'd have to go to the K-5 menu item that permits using the aperture ring on the lens, but A lenses don't require that setting (Good to know if you have even older glass, though).
the link to the user reviews of the FA works for me and get you to the user reviews of that lens
the link to the user reviews of the D FA * works for me and gets you to the user review of that lens
if the op has the M model, I doubt that the initial FA would have been used ??
_____________________________
upon further research, there are problems with using the D FA * 50mm with a K 5:
Pentax K-5 with HD Pentax-D FA* 50mm F1.4 SDM AW
This combination is compatible w/ limitations. Some original features are not supported.
Pentax K-5
HD Pentax-D FA* 50mm F1.4 SDM AW Compatible w/ Limitations
Aperture cannot be set;always wide-open
Standard Lens Features
Aperture: Auto
Focusing: AF
Mount: Pentax K (KAF4)
Read more at:
https://www.pentaxforums.com/compatibility/Pentax+K-5/HD+Pentax-D+FA%2A+50mm...#ixzz64i8CDqbc
