11-09-2019, 08:51 AM   #1
TT560 and Manual Use
All,
I feel rather silly, but I'm having difficulty getting my TT560 (Neewer TT560 Manual Flash 10003635 B&H Photo Video) to activate when I'm using it on manual mode. I have set it to "master" and turned on all the flash settings on my camera. No dice.
I got this recently - https://www.bestbuy.com/site/insignia-studio-flash-kit/8441755.p?skuId=8441755 - and on "auto" mode, the flash flashes, the strobes go off, and everything is massively overexposed (even with both flashes turned down to minimal). I'd like to set it to manual so I can adjust my ISO, etc. But when I set it to manual, the shoe flash never fires.
I've read the Pentax manual, but no dice. I recently got an AF-330FTZ, which I may try soon, but I'm still researching voltages.
Thanks for any guidance!
11-09-2019, 09:38 AM - 1 Like   #2
pschlute's Avatar
QuoteOriginally posted by jawats Quote
What shutter speed are you using ? You need 1/180 or slower.
---------- Post added 11-09-19 at 05:01 PM ----------
This is a dumb slave set up. I don't mean that rudely i mean that the slaves fire when they detect the master flash has fired and they put out their own flash at a pre-set power setting. "Dumb" just refers to the fact that there is no evaluation taking place between flash and camera.
So your camera needs to be in Manual exposure mode or X sync. Any other mode will have your camera select an exposure for the ambient light ..... and then you take the picture your master and slaves both fire as well and you have overexposure.
You will need to use a shutter speed less than your sync speed, so 1/180 or slower. Without a flash-meter to determine your aperture you will just have to use trial and error and the histogram. Remember that the parameters that will affect the flash exposure of your subject are aperture and ISO. Shutter speed will have no effect on the flash exposure, only on the ambient exposure.
Good luck
11-09-2019, 10:37 AM - 1 Like   #3
UncleVanya's Avatar
Avoid the af-330ftz it does not offer any modes that work well with modern digital cameras. The TTL type isn't compatible and it lacks a thyristor auto mode.
11-09-2019, 11:44 AM   #4
Good luck
Thank you for the advice!
So, there are small, round, PC sync cable jacks. Can they connect to a sync device of some sort? Is such a thing even necessary? I ask because, while these are triggered by an on-camera flash, many of the videos I'm watching recommend NOT having light from the front of the camera, particularly when taking "Rembrandt" type photos.
---------- Post added 11-09-19 at 11:44 AM ----------
Thank you. I shall avoid it!
11-09-2019, 12:31 PM - 1 Like   #5
pschlute's Avatar
No idea. I dont use cable
11-09-2019, 03:40 PM - 1 Like   #6
pschlute's Avatar
Yes and that is good advice. There are two ways around this.....
1. have the on-camera flash emit a low power output/with a diffuser/pointed not at the subject.
2. If you really want to get into lighting styles like Rembrandt or Hollywood lighting you need to get a more sophisticated lighting kit. You can get flash units that allow the on camera flash to act as controller rather than master (ie it triggers but does not add to the light for the capture). Or use radio triggers that allow you to trigger from the camera without having a flash mounted.
Sorry but while your existing set-up is good value for a starter kit it does have limitations.
ambient, aperture, camera, dice, exposure, fire, flash, flashes, light, master, mode, pentax help, photography, shutter, slaves, slower, sync, troubleshooting, tt560, type
Yongnuo RF-603N II & Neewer TT560? NicoleC Flashes, Lighting, and Studio 7 08-14-2019 03:35 PM
Confused about Step down level and the use of Manual and Auto Switch on the F. bladexngt Pentax Film SLR Discussion 5 05-24-2019 01:47 PM
What flash can I use for auto and manual lenses? Chetverovod Pentax Camera and Field Accessories 7 06-05-2018 09:29 PM
neewer tt560 not firing in time in wireless jalmeter29 Flashes, Lighting, and Studio 6 06-29-2015 02:49 PM
Do you use only manual focus lenses?Do a lot of folks use only manual lenses? heralu Pentax DSLR Discussion 12 01-05-2011 04:06 PM
All times are GMT -7. The time now is 08:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
