Originally posted by tokyoscape May I ask for pro and con of the Tracking mount vs O-GPS1?
O-GPS1 is tiny and adds no significant weight to your bag. The tracking mount is heavier. Regardless, you'll need a tripod with either one, and the tripod is the bulkiest part if you have to hike to get to a dark spot.
O-GPS1 gets calibrated using camera menus. It needs no knowledge of the night sky but in my experience is finicky; the same alignment process can yield very different accuracy on different nights.
A tracking mount gets mechanically aimed at Polaris, aka the north star, assuming you're in the northern hemisphere. Southern hemisphere is trickier because there's no bright star directly in line with the south pole. Technically it's supposed to be a offset but with wide lenses aiming straight at Polaris is okay.
If taking one photo, O-GPS1 takes less time to use than the tracking mount. If taking many photos, either with different composition, or many photos with the same composition for software stacking, then the tracking mount becomes much more convenient.
