Originally posted by MarkJerling Normally, the auto-exposure program on a Pentax camera will try to set shutter speed proportional to the lens focal length....I'm not sure that's what's happening at all.
This is happening. The camera does read and use the lens focal length (e.g using a zoom lens) as one of the conditions to set shutter speed. The way to see how the lens focal length changes the value of shutter speed is to use a uniform wall evenly lit, and zoom in and out the lens to see if the shutter speed is changing. I've done that experiement, and I've seen the camera adapt shutter speed to lens focal length to around 1/FL, e.g 50mm => shutter speed = 1/50th s.; 100mm => shutter speed = 1/100th s.
Now if the ISO hit the min possible value or max possible val, the camera won't change the shutter speed even if the lens FL is changed, because the objective of the AE algorithm if to expose correctly in the first place. If A is fixed, ISO is auto and T is auto, the camera will adjust ISO so that to have T = 1/FL.
---------- Post added 21-11-19 at 07:34 ----------
Originally posted by mikesbike if wanting auto adjustment with a change in lighting, but wanting to control shutter speed, Tv seems the most reasonable option.
Yes. Usually, I want to have control over depth of field, so I use the A mode. IF, on top of having control on the depth of field, I want to also benefit from the SR capability, I have to use the TAv mode, and I have to look at my lens FL and compute in my head the shutter speed that would work with SR. Let say I have set my lens to 105mm for a portrait and the shutter speed to 1/15th s., SR enabled, the camera lower to ISO to 100 blinking because there is still too much light, I have to manually dial a faster shutter speed again. That's 2 manual operations, whereas the camera could have done it automatically by itself. So, yeah you can call me "lazy", but I feel like Pentax camera don't take advantage of SR in the way exposure is achieved. Even if I use the green mode, the camera doesn't lower shutter speed and ISO when I enable SR. The whole Pentax AE operate as if Pentax cameras don't have any sensor stabilisation. Maybe 80% of photographs taken in the last 10 years by Pentax photographers could have had better quality if Pentax camera AE would have consider SR is exposure parameters! Imagine, one million photographs that could have been taken with a lower ISO if Pentax AE would compute differently when SR is enabled.
---------- Post added 21-11-19 at 07:38 ----------
My point is that Pentax messed around pixel shift to improve image quality a tiny bit (on tripod only), while they didn't see that they could massively improve image IQ by simply having AE algorithm gears down when SR is enabled when the cameras are hand held. IMO, AE not using SR status is so big, like the elephant in the room.
---------- Post added 21-11-19 at 07:40 ----------
Anyway, I'm still trying to find a way to have my K1 take advantage of SR within having to use manual mode and compute exposure parameters myself.
