11-27-2019, 05:38 PM   #1
Can it harm Pentax 6X7 to use without battery?
Pure beginner in medium format film; I've just received an ebay purchase of a Pentax 67 camera, it was a used and long-unused camera which came in a case with bits and pieces, extra films and extra batteries etc-- I loaded the film and battery but the battery test light isn't turning on so I assumed the batteries are old. I am used to shooting Pentax k1000 35mm which also requires a battery for light meter but still functions without-- so when I shot my first photo, the shutter seemed to jam. I read some forums so realised that it does in fact need a battery for use, I am just wondering, will it go back to normal upon installing a fresh battery or will I need to take some extra measures to return it to working order?
Thank you!
11-27-2019, 06:50 PM   #2
Aaron28's Avatar
believe batteries are required for operation
Pentax 6x7 - Pentax 6x7 Medium Format - Pentax Camera Reviews and Specifications
11-27-2019, 06:57 PM   #3
ismaelg's Avatar
My understanding is that as long as it is working properly, fresh batteries will let it complete the cycle and reset. But I can't confirm it.
Thanks,
11-27-2019, 07:15 PM   #4
Aaron28's Avatar
that's what I read in one of the reviews.....but have no experience
11-27-2019, 07:18 PM   #5
Silent Street's Avatar
The Pentax 6x7 and Pentax 67 (1969 and 1989 respectively) all require a battery for activation of the shutter and mirror circuits via the solenoid. It is not a manual/'batteryless" camera. As you are a beginner with this camera, it is best to use it with a battery, as designed. That said, a specific modification is available to use the camera without a battery so that extended time exposures (Bulb) can be used (e.g. for astrophotography) rather than limited to the 4-5 hour Bulb exposure with a fresh battery.
If the battery is weak or flat, pressing the shutter button will cause the mirror to stop half way. The solution is to insert a fresh battery, then use a matchstick or toothpick inserted into the reset nib on the left of the front of the camera (viewed from the front). Press the shutter once after that and wind on. Note that film is not necessarily required to be loaded for this reset step, but the camera must have film loaded at any other time for the shutter to fire.
To avoid any unexpected problems, please read the following:
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/372838-...ter-prism.html
---------- Post added 28th Nov 2019 at 01:23 PM ----------
Thanks,
The camera cannot complete a reset by itself with a fresh battery. Resetting is a user-intervention and a critical point point in operational fluency of the camera.
11-27-2019, 07:44 PM   #6
ismaelg's Avatar
Thanks for the clarification.
batteries, battery, camera, film, front, harm pentax 6x7, light, mirror, pentax, pentax 6x7, pentax help, photography, reset, shutter, time, troubleshooting
Selfie Harm - asocial media photography impact beholder3 General Photography 22 03-13-2019 03:36 AM
AM/FM button on lens may harm the lens? FilipWessman Pentax SLR Lens Discussion 17 09-08-2015 09:13 AM
Ya can't spell Ryan without Ayn, and ya can't spell Romney without Money. Who scripte jeffkrol General Talk 8 08-21-2012 05:13 AM
Can long exposure times harm the sensor in the K-5? m8o Pentax K-5 9 11-13-2010 09:30 PM
What possible harm could I have done .... daacon General Talk 58 08-07-2009 12:08 PM
All times are GMT -7. The time now is 04:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
