Originally posted by TwoUptons For a number of the simpler lenses I’ve taken apart, where each element went was fairly clear. Which side of the element pointed where, however, was often a tricky question, and not always one easy to answer, even with a lens diagram.
If you can easily take it apart, there may be some obvious candidates for flipping over...
^This is more or less what I was going to say.
It is highly unlikely any of the lenses are out of order, but the possibility of a lens being reversed in its position in not unrealistic.
Heck, I've done it myself when reassembling a lens.
Bonus points: You can create your own 'effects' lenses by reversing elements, removing elements and/or swapping elements.
