Originally posted by AstroDave
If you are looking directly through the optical viewfinder, you DON"T see the effect of image stabilization
Isn't that is basically backing up what I said?
Originally posted by VILLAINofOZ
looking through the viewfinder of my K-70 and my 55-300PLM lens,
Notice the comma - I just made it bold and bigger so you can see it better.
the image is stabilized in the viewfinder
Meaning it is
not shaking and not that the 'in camera stabilization' is done, seen or controlled from the viewfinder which I know is incorrect.
and does not shake for me
I thought that's what I said.
Originally posted by jacqui2
so it took a little getting used to with the image not being stabilised in the viewfinder,
This part of jacqu2's post is is why I answered the way I did.
I think you needed to quote someone else like :
Originally posted by othar
This is impossible. The SR system only works by moving the sensor. How are you getting a stabilized image in an optocal viewfinder except you are using in-lens stabilisation with a Sigma lens?
I didn't actually appreciate being told I am wrong when in fact I was correct in what I said all along.
Forums are supposed to be informative and helpful an not picking on a correct point of view.
