Originally posted by Apet-Sure I don't see how two images taken with a spread of 6 EV could turn out the same. Changing the exposure compensation would change the aperture, shutter speed, or ISO value depending what mode you are in. Two shots taken at at 1/40 sec. f/4.5, ISO 400 would of course be the same. Maybe I am misunderstanding the point you are trying to make. I don't equate EV (brightness of a scene) with exposure compensation (pushing up or pulling down the exposure).
Let's say the scene is a back-lit black cat on a sunlit snow field.
If one meters the white snow, the reading might be 1/1600, f/8, ISO 100. But shooting with that setting produces an image of dull gray snow and a pitch-black cat with no detail.
Setting EV compensation to
+2 while metering the white snow changes the setting to
1/400, f/8, ISO 100 and produces a picture with white snow and a suitably black cat with black cat details.
If one meters the black cat, the reading might be 1/50, f/8, ISO 100. But shooting with that setting produces an image of gray cat surrounded by over-blown white featureless snow.
-3 while metering the black cat changes the setting to
Notice both the "white snow +2 EVC" and "black cat -3 EVC" approaches produced the same exposure settings and created the same image. The only thing that matters is the final exposure setting, not how that setting as created by some positive or negative EV compensation adjustment.
The point is that EV compensation is used to adjust the meter reading based on the photographer's knowledge about the gray-level of metered object (is it white snow or a black cat?) in the scene and the photographer's intended gray level of the metered object in the captured image (should the grays of the scene be realistic or exaggerated?).
