Originally posted by lacror2 Thank you all for your responses and the information. Since the only lens that will work on a camera with the aperture block failure is one with a KAF4 mount, I was wondering if a wide-angle prime or zoom was available with this mount - or is the Pentax-DA 55-300 ED PLM WR RE lens the only lens manufactured with the KAF4 mount? Looking at the Pentax lens catalog (
http://www.ricoh-imaging.co.jp/english/support/pdf/pentax_acc.pdf), it appears that this is the only lens manufactured with the KAF4 mount. Is this the case?
The HD Pentax-D FA* 50mm/f1,4 SDM AW is the other one with its electromagnetic diaphragm control
But you are not going to buy this one for a K-50 with aperture problem, this is a lens for the K-1, maybe K3 and KP.
To large and heavy for the K-70 I'd say.
First get your K-50 repaired and enjoy the lenses you have.
For a proper test this is very simple: Use any lens with an A-Ring or any modern lens such as your Kitlens, DA50, DA35 etc.:
Set your K50 to AV and take a picture wide open (DA50 = f1,8) This will be dark if the solenoid is stuck, i.e. with aperture control failure!
Then same setting AV but closed such as f22 or whatever the max. value of your given lens is: This photo will be fine!
(you can use flash complete closed is difficult)
The other possibility:
Take a photo with liveview: Often those photos are still o.k. (but not always!)
Look into the front of your lens to see the iris (the blades)
When you switch your K50 into liveview the iris goes into f4 position!
This is still relativ open.
But if the iris closes completly, the solenoid is stuck.
It might still work because in Liveview the solenoid is used in a different way, switches twice and receives more milli-amperes because the mirror is up and when going down, there is an extra influx of energy.
You might be able to use your K50 for a while with Eneloop batteries (and the AA Adapter) but this won't last forever.
Only those who used Eneloops from the beginning and use the body very often (so high shuttercount) are sometimes lucky.
