A while back I picked up a K500 with the aperture block failure to use as a second astro body, mostly for doing wide astro shots with old all manual lenses. However for the life of me I cannot figure out how to get it into interval shooting mode. I have the dial set to M but in the menu Mult-exposure remains enabled and I can't see how to disable unless I set the camera to shoot jpeg and then set HDR capture but that doens't result in interval mode being set. I have tried setting the various drive modes to see if that affects it and none did.
I figure this is something that should be fairly easy to get set correctly and there is some setting that I am missing but for the life of me I can't find it. So here is the currently settings for the camera:
Custom Image - neutral
digital filter - grayed out but set to off
HDR capture - grayed out but set to off
Image Capture settings:
File Format - RAW
JPEG Recorded Pixels 16m
JPEG Quality - ***
Color Space - sRGB
AE Metering - Spot
AF Settings:
AF .A - Grayed out
Expanded Area AF - unchecked
AF Active Area - Spot
AF Assist Light - Unchecked
Lens Correction - Off Off
Multi-Exposure - Is not grayed out
Interval Shooting - Is grayed out
D-Range Settings - Off Off
Mode: Manual
AF switch: Manual
Firmware: 1.02
