Originally posted by Paul the Sunman CIF will only work with a manual lens, or a lens with an auto/manual switch.
I cannot reproduce this behaviour with my K1+15-30.
That should be "CIF SHOULD only work with a manual lens...". When you have a malfunction, you have to be very careful with your assumptions. If it was working like it should, we wouldn't be talking about it!
I cannot reproduce this behavior either, at this point. Creepy, freaky issue to have in my expensive and ultra cool retirement final camera set-up. Intermittent problems are always the worst.
---------- Post added 12-28-19 at 08:37 AM ----------
Originally posted by sergysergy That is really strange. Can you use it in other bodies to see if it has a similar behavior?
Two of the kids have Pentax cameras, so that is a possibility. Good call, could pin the issue to the just the body or just the lens!
I'll put that on my to-do list, although the priority dropped dramatically when the system quit doing it.
That being said, it is always a concern when you have a problem and it goes away but you didn't FIX anything...
It may come back at any point in the future. I'm not real happy unless a root cause is discovered and a solution found. Life has a way of bending that around, though; sometimes it's just not going to happen. Then we say "It was an anomaly" and try to look smart, as if that explains anything...
---------- Post added 12-28-19 at 09:20 AM ----------
Originally posted by DeadJohn This is just a guess. Maybe your shutter button is extra sensitive and air pressure from a quick zoom is activating the button.
Ah, this is why I love good forums! (and I'm starting to think this is a really good forum!!)
My first thought was 'good idea, but the lens doesn't get longer/shorter when you zoom like my 28-105 and 150-450 do'. So I got the 15-30, took it off the camera, and had a look-see. It doesn't get longer/shorter, but the internal element cluster DOES move for and aft when you zoom. Putting my fingers over the opening in the lens and zooming it, there is definitely air moving when you zoom. The camera and lens are both weather-proof, so air can't freely escape the system... This theory is standing up so far.
So, given that, why doesn't it do it now? When I was having the issue, it was literally the first 5 or 10 times I zoomed the lens since received. It's a brand new lens, so extremely few cycles on the zoom system. Could it have loosened up, reducing the air pressure difference when I zoom it? I don't have a model for that, but it seems at least plausible. If so, the problem is gone, never to return. But how can we prove it?
If you are reading this and have, or are getting, the 15-30 Pentax lens; please check it out. When you first attach the lens to the camera, turn the camera on and zoom in and out a few times. See if your camera body takes an image without you touching the shutter release, and if it stops doing it later. Then please, PLEASE come back to this forum and tell us what you've found! That could be very telling. Thanks in advance!
And finally, thanks to each contributor! Pre-internet I would have shrugged my shoulders and carried on, trying not to worry about the lens/camera. With the internet I've enjoyed some excellent input and hope to get even more if someone follows up with a report on Their new 15-30 behaviour. Awesome!!
