Originally posted by Tonytee
Yes, but it plainly evident in the third photo where the speck on the jar is not there. The debris to the right is also not there. However, since you need more proof, I will upload more images taken with higher exposure levels where the debris does in fact appear. Thnks. Tonytee.
Hi Tony
It's not that I need more proof... I'm attempting (poorly, perhaps) to explain that any debris on the
sensor -
anywhere within the image frame, corners or otherwise (and, therefore, including the speck over the jar) - will be clearly visible at a small aperture such as f/22, but much, much less visible (if at all) at a wider aperture such as f/8. As such, for the comparison of images from two different lenses to have any meaning at all in this test, the photos from each need to be taken
at the same small aperture (such as f/22). If one or the other is at a different, wider aperture like f/8 (as in your third image), you're not comparing like for like.
Both must be taken at the same small aperture to conclusively prove if this is dust on the sensor.
I hope that makes sense, and my apologies if it seems that I'm being difficult... My motive is only to ensure a controlled test that gives
you the information you need to conclude whether or not the debris is on your sensor, or in your lens
