Originally posted by rogerstg The tests you did were not suitable for determining the extent of de centering. You might want to test for de-centering before making that conclusion.
Right. And all at closer distance. Results at closer range can be different than at normal-to-distant range.
However, from what I do see in this very non-definitive teat, the lines on the right appear to be sharper than those on the left. Not highly, but to a degree. But the slightest lack of precision as to the camera and lens being square to the grid being photographed can also produce a false impression.
By focusing on a solid, well-defined subject at some distance and wide open to reduce DOF, then moving the camera to place the object at different points of the frame, each shot is really focused at the same distance and plane, the camera simply being rotated from the same position, this eliminates that problem. So the focus, the distance, etc. will be identical for each shot, but when the shot is actually taken, it will come through a different area of the lens. Thus other variables are eliminated while the lens performance itself remains.
