Firstly, Hi, and sorry for making my first post a question. Still, we all have to start somewhere.
I've had a KX for a long time (and a Pentax film cameras before that). I've never had really consistent results from the KX, possibly because I've only used the kit lenses and the 18-55mm isn't brilliant. The kit 55-300mm I have is a lot better IMO. I recently bought a 1" Canon compact for stuffing in a pocket whilst climbing mountains and found it took better images, which suggested it might be time to bite the bullet and replace the KX.
I found a bare K70 on offer and bought a 16-85mm lens second hand to go with it, as the range is just what I want for landscapes (although perhaps a bit heavier than ideal).
Unfortunately, that's where the problems start.
Although reviews suggest the 16-85 is pretty sharp across the frame, I've not been able to reproduce this at all. I've tried it on the KX and it doesn't focus in live mode, so I'm not 100% sure whether it is the (new) camera or the lens at fault, as it doesn't focus perfectly using the KX viewfinder. I've tried the kit 18-55mm on the new camera and it is definitely not sharp either, so I'm inclined to believe the problem is actually the K70, although I haven't really got a good place to test it formally.
The example below might suggest it is an angled sensor but other images are just a bit blurry on the left and not obviously near-focused. It does seem to be infinity focus that shows it at its worst though.
Any ideas where to start? I don't want to send the wrong item back.
