I have seen it said that the non-rechargeable AA batteries may perform longer than the rechargeable type, but I have also seen it said that the rechargeable type may perform longer. I have used both, for example packs of eight AA batteries from a dollar store, and I also use my AA rechargeable EBL batteries. You may want to use a small number of the rechargeable type at first and see how long they last. If they seem to do well, you could use them and keep some as backup also. Maybe you could start with 4 rechargeable batteries and a 4 slot charger. If you do use rechargeables, you would want to make sure the batteries are in the charging slot bays with the negative and positive ends set right, because if you don't it may ruin the charger and/or batteries.
Happy shooting!
