The only reason I asked is I found a new K3 and am tempted to buy it.
---------- Post added 01-12-20 at 11:16 AM ----------
Originally posted by Alnjpn I can comment on the K3 but not the KP. I have had the k3 for 3 years and have had ongoing AF problems. It is fast but most certainly NOT accurate. (This is through the viewfinder, accuracy in Live View is fine). I have tried adjusting the lenses and cleaning the Af module but still the problem persists. This may be a one off problem although I have seen similar comments on this forum. I have an old Canon 6D which I use for portraits. While the AF is much slower it is considerably more accurate and reliable. If AF accuracy is important you might wan't to avoid the K3
I had similar problems with my K1 mkIi. Every lens I own was out of focus. My K1 was perfect. So, I sent it to Precision to check. Boy, did I dread that.
