01-14-2020, 06:36 AM   #1
Can I use a 1G SD card to upgrade firmware on an old ist DS?
I have an old ist DS that serves me well but I wanted to use a bigger SD card. Unfortunately, I don't seem to be able to perform an upgrade because all the new cards give a card error. Can I use the existing standard 1G card to get the upgrade done to version 2.02?
I note that the instructions say use a card of 8G or greater.
Any advice gratefully received, thanks.
01-14-2020, 07:13 AM   #2
boriscleto's Avatar
Anything less than 4GB should be ok. Anything 4GB or larger is SDHC.
The instructions say the card should be 8MB or larger...the .bin file is only around 1MB in size...
01-14-2020, 07:21 AM   #3
UncleVanya's Avatar
I had a similar issue with the K100D. Finding a small enough card was difficult at that time! Once performed the updated formate was useful as it raised that limit on the k100d...
01-14-2020, 07:27 AM   #4
MossyRocks's Avatar
I don't see why it wouldn't work. A 1GB card would be a standard SD card which should be supported by everything that reads SD unlike SDHC or SDXC cards. This assumes that the old SD card still works and hasn't worn out which can happen.
01-14-2020, 09:20 AM   #5
Not a Number's Avatar
Worse comes to worst you can put a 1 GB or smaller partition on a > 1GB card and repartition it to full available space afterwards.
Refer to the volume and partition tools appropriate to whatever OS your computer is using.
Note: you need at least version 1.02 to access cards greater than 1 GB.
01-14-2020, 11:02 AM   #6
UncleVanya's Avatar
Are you certain this works?
6 Days Ago   #7
QuoteOriginally posted by boriscleto Quote
Thanks for all the advice. The upgrade was successful and I can now use the modern cards. The increased speed of the cards has greatly improved performance using the motor drive for multiple exposures.
1g sd card, camera, card, pentax help, photography, sd, troubleshooting, upgrade
Pentax ist ds firmware upgrade D Whitlam Visitors' Center 3 06-26-2018 01:48 PM
yaaay, successful update to ist DS firmware 2.02, now I can use my 4Gb SDHC card jamelikat Pentax DSLR Discussion 15 06-21-2017 07:59 PM
Can I use F, FA and FA J lenses on my *ist D/*ist DS? Ole Pentax DSLR and Camera Articles 4 03-16-2008 01:10 PM
For Sale - Sold: FS: Brand NEW SD/SDHC Cards - Kingston, SanDisk, Panasonic, etc: 4GB, 2GB, 1G Genes Pentax Sold Items 2 12-06-2007 09:42 AM
Can I use smc Pentax-A lenses on my *ist D/*ist DS? Ole Pentax DSLR and Camera Articles 3 05-18-2007 10:23 PM
All times are GMT -7. The time now is 02:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
