Originally posted by wolfone A related but somewhat different and older approach to "digiscoping" with Pentax spotting scopes is the use of the now discontinued Pentax PF-CA35 K-mount camera adapter. It replaces the eyepiece and allows the direct attachment of a K-mount camera (obviously without any lens) to the spotting scope. The image magnification is not as high as when using the eyepiece and an external camera but with a PF-65 scope the focal length would be 780mm with a full frame camera (K1, K1ii) attached and 1,190mm with an APS-C Pentax Camera (both at f12). I would be interested in anyones experience using the PF-CA35 adapter.
This adapter can still be found a new for sale as of today. The only matter is , accordingly to descriptions I found ,this adapter is an eyepiece itself with fixed focus (35mm focal length if I got it wright)
https://www.pentax2u.com/products/Pentax-PF-CA35-K-Mount-SLR-Camera-Adapter/525
. While the front lens element of a spotting scope is most likely an achromatic doublet (two lenses,positive and negative glued together) and this type of telephoto design was used in 1950-1970s, the rear lens element of a spotting scope is a lot more complex than a single negative lens in old telephoto design. Will this adapter improve an image quality compering to an old telephoto optics? It seems that there is no way to gather an image from just the front element alone while having a typical spotting scope structure. I acquired a few old Tokinas 500mm and 600mm and tried them out for birding. They showed decent results on APS-C, if the light was good. They both could resolve small details and exhibit good contrast at 12-20 m distance of a medium size bird. Chromatic aberration was awful though as well a halo around bright objects and required more effort to be made in post processing . It seems that in terms of the optical design (from element) they were similar to a spotting scope.
I myself am tempted to buy this Pentax scope adapter with Pentax 65ED spotting scope, but I'm afraid that the image quality will not rise above the level of old telephoto of 1970s...
