02-08-2020, 03:02 AM   #1
Troubleshooting external flash on K-3
Good morning,
I'm trying to connect a Promaster 7000 flash to K-3, it won't fire and it gives me this distress mark on the LCD screen. What is it? Generally speaking, for some reason I couldn't find it online - where should I've looked it up?
Thank you!
SM-G950U  Photo
02-08-2020, 04:05 AM   #2
pschlute's Avatar
QuoteOriginally posted by mnovikov Quote
A quick google suggests the voltage may not be compatible. It also appears to be a TTL flash so wont work in P-TTL in a Pentax camera.
02-08-2020, 05:43 AM - 1 Like   #3
If you mean the red icon (RED Blinks: GPS data cannot be obtained), it is only when the GPS Unit (O-GPS1) is attached into the K-3's hot shoe, your flash may be mistakenly identified by the camera as the GPS Unit.
02-08-2020, 06:22 AM   #4
Oldbayrunner's Avatar
"The Promaster FTD 7000M flash was not designed for the low sync
voltage requirements of digital cameras. This flash will not work properly
or safely on the Pentax "
The only way to get one to work would be off camera using a trigger system.
02-08-2020, 09:49 AM   #5
Don't even try it anymore, it is as others answered.
I think the Promaster 7500 EDF was the first one for P-TTL, one can find it cheap these days but you might need to send it in for a firmware update for more modern Pentax bodies!
02-08-2020, 11:36 AM   #6
Otis Memorial Pentaxian
QuoteOriginally posted by Oldbayrunner Quote
...or with a voltage reduction adapter such as a Wein SafeSync. Either way, the usefulness of this particular flash is limited, except as a full manual flash.
camera, flash, k-3, pentax help, photography, troubleshooting
Shutter Speed not changing? Need help troubleshooting Pentax K1000 ncpatel329 Pentax Film SLR Discussion 7 05-06-2019 05:12 PM
Capture Tethering Troubleshooting Nacho Guevara Pentax Medium Format 3 11-28-2018 10:41 AM
Sigma 70-200 f2.8 EX APO (non-hsm) - troubleshooting and/or worth the repair? Flipside Troubleshooting and Beginner Help 5 07-28-2018 03:54 AM
K5 II On Board Flash Troubleshooting IsaacT Troubleshooting and Beginner Help 7 01-14-2015 10:15 PM
Travel external order and external disorder there's only the seeming phenomenon zztopd Post Your Photos! 11 02-17-2014 09:47 PM
All times are GMT -7. The time now is 08:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
