02-17-2020, 04:02 PM   #1
Ricoh Pin, or another error? - Sigma Zoom Master 35-70
All,
I got a zoom master by Sigma, MF, 35-70, 2.8 - 4. Cute little lens with macro. Only thing is, I think it might be a Ricoh mount. I've attached a couple pictures. The first time I tried it on my K-1, it locked up. With a bit of fiddling back and forth, it popped off again. Thoughts?
--Jonathan
02-17-2020, 04:11 PM - 1 Like   #2
amateur dirt farmer
pepperberry farm's Avatar
it is a K-mount, which both Pentax and Ricoh used.... but that appears to be a Ricoh pin, which would cause the problem you described...
02-17-2020, 04:23 PM - 1 Like   #3
johnha's Avatar
The best way to remove is to take the mount off as suggested from this link: theatre of noise: Ricoh Lenses On Pentax Cameras -- The Ricoh Pin Fix
02-17-2020, 04:39 PM - 1 Like   #4
QuoteOriginally posted by pepperberry farm Quote
Pepper,
Thanks!
---------- Post added 02-17-20 at 04:39 PM ----------
QuoteOriginally posted by johnha Quote
Johnha,
Thank you!
02-18-2020, 08:17 AM - 1 Like   #5
QuoteOriginally posted by jawats Quote
All,
--Jonathan
The green arrow points at the place were the Ricoh-pin is located (but removed on this lens, took me 3 minutes)!
The pin on the right bottom side is for the A-contacts and important!
A simple method is first to try to force it downwards. Usually it is held by some sort of spring which allows to be bent backwards, no danger involved doing so!
If this doesn't work, removal is pretty straight forward, it seems you lens has just 3 JIS screws (a PH00 will do as well but JIS is best).
Whenever the Ricoh-Pin gets stuck, it is because it is right at that place were the screw-drive mechanism of Pentax DSLR bodies pushes out in AF-position, but as these are A and not AF-lenses and Ricoh had the reason to fit the Ricoh programmed exposure cameras.
- First thing to do is to set it on M instead of AF, which often does the trick.
- Next possibility is to play around between M and AF and gently move the lens, often it unblocks.
- If this won't help, a razorblade or scalpel gently inserted between the lens and the K-bajonet will do the trick.
02-18-2020, 03:56 PM   #6
QuoteOriginally posted by photogem Quote
The green arrow points at your Ricoh-pin! (The pin on the left bottom side is for the A-contacts and important!)
Whenever the Ricoh-Pin gets stuck, it is because it is right at the screw-drive mechanism of Pentax DSLR bodies.
Next possibility is to play around between A and AF and gently move.
If this won't help, a razorblade or scalpel gently inserted will do the trick.
Photogem,
Perfect! Thank you. I actually bought some JIS drivers a few years back for another lens project.
02-18-2020, 04:15 PM   #7
boriscleto's Avatar
Don't remove the pin the green arrow is pointing to. That is not the Ricoh pin. The Ricoh pin is the one next to the bayonet flag.
I have never had an issue with a Ricoh pin that wide.
02-19-2020, 12:55 AM   #8
Correct, fog in my head due to flu (since 2 days).
Corrected!
Attached a photo of a lens with the Ricoh-pin just pushed in.
Anyway: The TO had issues with a pin that wide! It locked up in his K-1.
Here is a short tutorial, I hope no errors within... the fog is still hanging around:
Tutorial: Ricoh-Pin removal - PentaxForums.com
02-19-2020, 06:36 AM   #9
Corrected!
Thank you Boris, and thanks for confirming, photogem. I hadn't done anything with it yet, thankfully.
02-20-2020, 05:43 PM   #10
Corrected!
Well, I got the ricoh pin out, but I think there was a tiny ball bearing in there that popped out and ran. Now the aperture doesn't click into place and the lever is wonky. Perhaps I mis-aligned it. Does anyone have the desire for an inexpensive project lens?
02-21-2020, 12:29 AM   #11
Then you must have somehow lifted the A-ring off, the tiny ball which sits there can only come off if this happens.
Too bad. But that's how we learn. I made worse mistakes. Yesterday I sat 1 hour with the mechanical pop-up-flash mechanism of a K-7.
One moment (fog) of non-attentiveness and the part fell into 3 pieces with a spring holding that hook in position.
Nevertheless, this one is solved and works again.
02-21-2020, 07:42 AM   #12
I have a few extra bearing rolling around...so to speak....from other lenses. I might try to get one in there. Or simply save the lens as a curiosity. At least I only paid $20 for the lens and the Program A that came with it. I now have some 10 - 15 old Pentax bodies...maybe I'll offload them here or on eBay in bulk.
camera, master, pentax, pentax help, photography, pin, ricoh, sigma, troubleshooting
Sigma Zoom Master 35-70mm f/2.8-4 lens Moggman Pentax SLR Lens Discussion 4 05-25-2015 12:10 PM
Sigma Zoom Master 35-70mm f3.5-4.5 AF, not macro JimJohnson Pentax SLR Lens Discussion 2 10-21-2012 07:16 AM
Sigma 35-70mm f2.8, Zoom-Master, MF Macro? 1 Snap Music! Pentax SLR Lens Discussion 2 08-21-2011 01:25 AM
Sigma Zoom master 35-70mm f2.8??? xjjohnno Pentax SLR Lens Discussion 2 02-06-2009 05:09 PM
All times are GMT -7. The time now is 09:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
