Hello, nice to greet you all
Recently acquired an enlarger m42 lens on ebay for $ 1. This type of lens has no focusing mechanism so an adapter is required.
Checking on ebay and amazon I see different focal lengths of the adapters which generates a doubt to buy the right one.
The enlarger that I acquired is a: AMAR PZO Red P f4.5 / 105mm M42 (attached image) looks like a normal m42 lens, have 10 blades, but dont have the focus ring.
In amazon I found the following adapters m42 to m42 ranging from 12mm to 90mm. (attached image)
My question is if I buy for example the adapter 35-90mm will I transform the enlarger that is originally a 105mm fixed to a zoom lens? And if I buy the 15-26mm I transform it into a wide lens?
Or regardless of the adapter will I always have 105mm? How does this work for this type of lens?
I can't find a specific adapter for 105mm.
I appreciate the help you can give me.
Have a nice day
