Originally posted by Wheatfield With the exposure being what it is, noise is guaranteed. This isn't a camera fault, it is a user error. I believe an earlier post alluded to underexposure being brought on by the large amount of white (ice) in the viewfinder. If the image is cropped, that will just make things worse.
I agree with Wheatfield's assessment. I sometimes shoot hockey, though usually roller hockey- club or college. A bright floor or ice can fool the meter. I see you are shooting in Manual mode- a good idea, because the background changes constantly, changing the light meter readings, though exposure of the players remains more or less constant. But believing the meter's reading in this case is tricky and misleading. Your settings look ok as far as shutter speed of 1/500 sec being adequate to freeze action of players, using the wide-open f/2.8 aperture, but additionally for typical indoor rink lighting you'll need at least ISO 2500, or better yet 3200 for those settings. If you can find a tan, green, blue, or gray mid-tone area under the same lights, switch to spot meter then take a reading from that area to get a better idea of exposure. You can temporarily switch to manual focus for that purpose so your lens does not hunt, since you do not necessarily need to be in focus to take meter readings. You'll probably find the ISO settings I mentioned to be verified.
After such use, just be sure to restore your standard settings. If you forget and leave the meter on spot, you will no doubt be getting many odd exposures when subsequently using your camera in one of the auto-exposure modes! As to focus, you won't have any AF!
