03-08-2020, 04:06 AM   #1
Green button replacement possibility?
This may be a really stupid suggestion / request but might be a boon for arthritic hands like mine.
Is it possible to remove the green button on the body and replace it with a "G" on the selector dial which then dictates that the camera body then stops the lens down mechanically (as is done by the green button)? Allowing the continuing press of the button to take the image. Obviously this would require a new body from Pentax.
Some customization of ISO / speed may be possible if required.
I have many manual only lenses needing green button metering and my finger and thumbing on my K-5 is not very adept.
My being shot down is not a problem.
03-08-2020, 07:23 AM   #2
Aaron28's Avatar
the constant 'stopped down' would be using Av mode instead of M...….use the green often and hafta keep in mind it's placed differently on the k-50 and k-3ii
03-08-2020, 08:00 AM   #3
All K mount DSLRs have the so-called crippled KAF2 mount which is missing the mechanical aperture coupler required to do what you want. The coupler wasn't needed for new lenses so was dropped to save costs. Pentax would need to go back to the KAF2 mount to make that possible but I can't see that ever happening as they need to sell new lenses which don't need it.
When the *istD came out it didn't even have the current green button functionality. To use old lenses you had to partially decouple the lens from the mount and operate in stopped down mode. Some people even drilled a new latch hole in their manual lenses mounts to make this easier and safer.
03-08-2020, 01:53 PM   #4
TBH I have pretty much abandoned the green button - too clunky. I just chimp and bracket.
03-10-2020, 12:17 PM   #5
With Takumar and similar M42 lenses you can stop down without having to use the green button:
- Pentax set to Avor Tav mode
- Focus with the lens wideopen
- Stop down and half-pressthe shutter: The camera meters now.
- Full press, i.e. takethe picture.
body, button, button replacement, camera, pentax help, photography, troubleshooting
Disable green button for back-button focus? Igor123 Pentax K-1 7 06-03-2019 08:01 PM
Landscape Green, Green and more Green AussieTrev Post Your Photos! 6 08-10-2018 03:26 PM
Question Possibility of a Sears Lens Review slot? Dewman Site Suggestions and Help 2 07-28-2014 12:28 PM
Green button and AE-L button voyager13 Troubleshooting and Beginner Help 7 06-28-2012 12:26 PM
Green button or +/- button for meter? kidblue Pentax SLR Lens Discussion 15 07-29-2011 07:10 PM
All times are GMT -7. The time now is 06:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
