Originally posted by TwoUptons
My first guess would be that the dial was removed for some reason and then put back on in the wrong position...
If you've had the camera the whole time and this is new behavior, however, that probably would rule that out, though I'm not familiar with that specific mechanism -- it may be possible it slipped during use, having the same effect.
The fix for that would probably involve finding the service manual and popping off the dial... (or leaving it the way it is and just adjusting...)
For the dot in the otherwise empty frames... a couple of things I'd want to know...
Should there have been images there? Do you remember shooting photos where the blank frames are? Or are these random blanks between known good shots?
Are the dots really there in all your images? loot at the prints from the good negatives... is there a bright light in the middle? That doesn't appear to be the case from what I can see on the single negative above the blanks, but it's good to know...
Does your camera have a winder? Is it possible the winder is banging off a couple of frames when you fire once?
What was going on between good frames? Did you move inside to outside or have other big changes in light? Was there a flash involved at any point?
Do you lock the camera before putting it in a bag? are the lenses capped when you do that? is it possible it's getting bumped in the bag while ready to fire?
Based on Aaron's idea, I'm going to suggest that your blank frames are light leaking in from the viewfinder during a 16s exposure with the misaligned dial...
Those would help us get you an answer...
-Eric
I found the XR-7 from outlet for 10 bucks. Otherwise it works well, not sure about the light seals though. I guess someone has taken the dial off then
. Found the repair manual and I'm going to fix it once I find a screwdriver small enough.
The blank images are from KR-10. The body is in mint condition except that it underexposes by 1 stop but that's not an issue for me. The images shot on colorplus were around 15s exposure, if I believe correctly. I never scanned the empty screens as there's only a black dot, even the frame background isn't exposed and all I remember is hearing the shutter go, as it's pretty loud. Delta 100 frames 13-16 were empty too. I can't wind the film when the shutter release is pressed and I'm not goofy enough to accidentally press shutter 3 times in a row.
I always advance the film when I'm about to take the photo, as I'm not sure if it can hurt the spring if I leave it loaded and never fire it. I Find it hard to make up any explanation for small dots in the middle, because dot bright enough to be visible, should have the background lit, but as seen in the image, there's nothing there. I couldn't replicate the issue, body works flawlessly. I just finished Berlin & Fomapan 400 so we'll see if there's anymore empty frames.
---------- Post added 03-08-20 at 11:37 AM ----------
-Eric
There's no dots in other images. I usually shoot outside both day & night.
Here is couple shots.
https://assets.community.lomography.com/6f/885e311fedb904f3d1c9cd1709e432d1f...094b6180ac0bbc https://assets.community.lomography.com/42/13e694a6f7bdc38167612d2a2d5a58667...328fdda98790d2 https://assets.community.lomography.com/90/6b73102635185f12c5f4234a6d569384e...75b07c8ffe8944 https://assets.community.lomography.com/8b/9a01fa78b34ec19d34e920425a2bda0c4...1fb36516beba02
