03-11-2020, 11:18 PM   #1
No date memory in K-r. What card speed to use?
On start up my K-r asks for date and time to be entered. Every time I turn it off and back on again the entered data is lost and needs to be entered again. I'm assuming that there is an internal battery that is dead. Might there be any other potential cause? Is this an easy DYI fix? What kind of battery is it? How and where is it accessed? Through the bottom plate?
Also, what is max write speed for K-r? In other words what card do I want without going overkill? Sandisk Extreme Pro is what I use in my K-3. I think the one in the K-r is maybe 20 mbs but seems too slow.
03-11-2020, 11:32 PM   #2
No internal battery, the main battery powers the date and time, it should be retained, even if the battery is removed for a short time. Here's a link to the manual.
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-r.pdf
03-12-2020, 01:10 AM   #3
QuoteOriginally posted by mkgd1 Quote
How does it buffer the clock?
03-12-2020, 01:22 AM   #4
i_trax's Avatar
some cameras use capacitor to keep settings
03-12-2020, 01:50 AM   #5
QuoteOriginally posted by i_trax Quote
A broken capacitor would propably alter the clock. Do you see the clock speed being off?
03-12-2020, 03:55 AM - 2 Likes   #6
It is not a broken capacitor (some say it is an ELNA supercap which is not the case and does not work!)
but it is the back-up battery on the mainboard.
This is a 3V rechargeable Lithium, original Seiko MS414, the Seiko MS621 works fine as well (is even better due to higher capacity).
This problem occurs when one leaves the camera for a long time without the normal battery (Eneloop would be the best for the Km/kx/kr)
The DIY fix is not easy but if you have good soldering skills it is doable.
A magnifying lamp would be very usefull, because the pins of the battery are very small and very close to each other, to "bridge them" happens very quickly.
Also nearby there are few SMD resistors which you don't want to touch at all with the tip of your soldering iron.
At least a pencil-tip soldering iron with low wattage (15 at the most) is needed,
temparatur controlled is better, a soldering needle is the best!
Steps: Disassembly as shown in my tutorials for the K30 but simpler.
You need to take the back off with the LCD as well, it clips with a connector to the mainboard.
Here the tutorial for disassembly of the K30, which is almost identical here as the K-r:
Manual solenoid replacement Pentax K30 / Discharge flash-condenser / Solenoid choice - PentaxForums.com
And here a rather frustrated part tutorial for the K-r:
Fix a forgetful Pentax K-r
03-12-2020, 09:06 PM   #7
QuoteOriginally posted by photogem Quote
Thank you for this. I keep this K-r body as a backup and almost never use it. I have stored it without the main battery installed because it seemed to discharge slowly. This explanation makes sense, (hence main battery slowly discharging). I thought if this was an easy fix I would do it before I gift it to my daughter when I purchase K-1 ll or K-new. The repair is beyond what I am willing to attempt as my hands are not that steady and I don't have the tools.
---------- Post added 03-12-20 at 09:11 PM ----------
Anyone care to comment on card speed as asked in original post? Thanks.
03-12-2020, 11:43 PM   #8
The Pentax K5 is said to write with 30mb/s, but actual tests have shown more in the region of 22-25mb/s.
UHS-1 is not supported, so waste of money.
I daubt the Kr is faster.
What is written on the card is how fast the card reads!
Writing usually is slower. So a 45mb/s might do the trick.
battery, camera, card, date, date memory, k-r, pentax help, photography, post, time, troubleshooting
Photo Taken Date vs Making Date RoundWharf General Photography 16 02-12-2019 02:53 AM
SanDisk memory card works on PC but says 'memory card error' in K-S2 kudzx Pentax K-S1 & K-S2 9 02-15-2017 09:03 AM
K3 & K3-ii memory card write speed Glospreys Pentax K-3 14 05-30-2016 06:04 AM
May 1st, 2012 A Day Without the 99% No Work No School No Housework No Shopping jogiba General Talk 4 05-02-2012 02:48 AM
K100D Super memory card speed Antitrust Pentax DSLR Discussion 3 09-10-2007 09:32 AM
All times are GMT -7. The time now is 02:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
