03-14-2020, 11:44 AM   #1
Information of flash mode in images.
Hello,
I am taking images using the built in flash of my K5. Some with plain flash, others with Slow-speed Sync, others with Trailing Curtain Sync. But pressing the Info button in playback I can not distinguish which is which. It shows the flash compensation but no information for the flash mode. What can I do?
03-14-2020, 12:27 PM   #2
Aaron28's Avatar
maybe go with the exposure times??? I believe the exif only states 'flash fired' or 'forced flash'......would be cool to have 'flash data'
03-14-2020, 01:57 PM - 1 Like   #3
Otis Memorial Pentaxian
ExifTool is capable of reading the flash mode from the makernotes section of the EXIF. Using that tool, the tag name is FlashMode. For example, that tag had values that mapped to the following from a trailing curtain exposure using the internal flash on my K-3:
Code:
Flash Mode                      : On, Trailing-curtain Sync; Internal
...using exiftool -k -g -a <filespec>
03-14-2020, 02:10 PM - 1 Like   #4
The Pentax Digital Camera Utility (PDCU) is also able to extract and display the flash mode.
Stee
03-15-2020, 03:02 AM   #5
Viewing flash mode of images on camera.
Thank you all for the suggestions. I do not know if these applications work on ubuntu which I exclusively use. I needed though to know on the field what flash mode I have used for images so I can make adjustments right away. To see later at home what flash mode has been used is of little help, I will have missed the opportunity.
03-15-2020, 06:54 AM - 1 Like   #6
Aaron28's Avatar
QuoteOriginally posted by Hidrieus Quote
I have a 'field book' which is still nicely wrapped in its heat shrink that have intended to use to take notes myself.......i'm too lazy but maybe you have better fortitude!
03-15-2020, 10:17 AM   #7
35mmfilmfan's Avatar
Couldn't you sort of write it down, or make notes on your mobile, or something ?
03-15-2020, 11:24 AM   #8
If you don't know in the field what your setup for the last several shots has been, there is that can be done. What can we say? Keeping good notes is the traditional, pre-EXIF, approach, particularly when learning a feature or doing testing for effect. Perhaps that might be an option.
BTW...in regards to slow speed sync. It is solely related to turning off the camera's efforts to avoid ambient light ghosting with flash and auto-exposure. It is a option in P, Av, and Sv modes only, and is on by default when using trailing curtain sync in those modes. If you are doing trailing curtain sync, you either have direct control to set your shutter speed low enough or are trusting the camera to do it for you. When I have used that mode, I have been using manual exposure (M) mode.
camera, flash, flash mode, information, information of flash, mode, pentax help, photography, sync, troubleshooting
Need information how to get focus pulse / distance information from camera sliawatimena Welcomes and Introductions 12 01-09-2019 07:31 AM
K-1 Mii Manual mode has 1/3 of the required information to make an exposure straton Welcomes and Introductions 13 08-28-2018 12:43 AM
Does 1:1 crop mode RAW file contains 3:2 picture information? Medex Pentax K-1 & K-1 II 2 12-28-2017 12:51 AM
Detailed Information Playback Mode Cowboy Pentax K-1 & K-1 II 3 07-02-2016 11:11 PM
AF-A mode ? I can't find any information thibs Pentax DSLR Discussion 12 09-23-2008 12:51 PM
All times are GMT -7. The time now is 06:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
