Originally posted by Gfinny I've been shooting my 67 recently and when I get to the end of the roll I don't get the "freewheeling" you mentioned. I still have to advance the film and fire the shutter to wind the film back up. Is there a reason for this? Or had a similar experience.
Frame #10 is the end of the roll, in 120 format.
The shutter cannot fire after frame 10, but it can if you have the format set to 220 and using 120 film! That is something to check.
Once wound on and the leader has disengaged from the left hand side of the camera, that is when the 'freewheeling' will be noticed (or loss of tension, as you are essentially just lightly winding on the end of the roll to the take-up spool). The shutter is also disengaged on completion of the last frame of the respective film format.
Both roll and take-up clasps should be checked and double checked once the film is loaded and before the back is closed to ensure they are set and locked down correctly.
