Originally posted by aslyfox my cameras K 3, K 3 II and KP all have a setting which runs the dust removal system when the camera is turned on [ and when it is turned off ?? ]
I use it
and then I will check how successful the system works from time to time
seems to do a good job for me
check pg 40 of your owner's manual
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-5.pdf Thanks, Allen. I have had this turned on.
And Peter, I will definitely be using PP to remove any remaining spots, since there aren't so many and only show up in specific situations..
I am trying to think what I did that caused the dust in the first place. Hadn't been a problem ever in 10 + years of digital shooting. Must've changed a lens in wrong place, at wrong time, or in wrong way. Per SpecialK's suggestion, I'll make sure I have camera turned off when I change lens. Not sure I've ever been mindful of that.
