Originally posted by bdery The beep is the first thing I turn off when getting a new camera.
Yes, it's been this way for a pretty long while, which is why I haven't noticed the camera not indicating this for so long. I turned it back on, to explicit see when this occurs now.
Originally posted by stevebrot Setting up for back button focus with AF on half-press disabled will change things. If not, focus confirm will be active as long as the meter is active after half-press (at least on my K-3), though I have found it easiest to leave my finger on the shutter button on half press while doing manual focus. Alternatively, extending the meter shut-off time in the set-up menu may help.
I'm not sure what you guys are saying here? Are you that by setting up Back-Button focus, that it could be the reason that it appears to be happening less? In terms of Back-Button focus, I don't quite use it the way most would think when considered when they say Back-Button Focus. I guess I do the opposite, where pressing the AF-button stops the AF when pressing the shutter (if that makes sense)
