Originally posted by seaK70 Is there a problem with aperture on Pentax K70- when I take a photo it is very dark but settings are all ok. when I se he viewfinder images are dark but when I use the screen images are brighter but blurred like the shutter is open longer?? I took it into the store I bought it at and they said it is a problem with camera body aperture and not the lens. I have had the camera for two years so no warranty but have hardly used it- Is it worth it to send it away for a repair? or better to buy a new body? and is it know that this problem is common?
My first (expensive for me) camera and am very disappointed as it has not been used much. Any advice?
Most likely the usual jammed solenoid, ALL symptoms point at it, and yet, a test with another lens could verify it but it seems you don't have one?
You can find out very simply by following those instructions:
How to detect aperture-block failure/stuck solenoid on Pentax K-70 - PentaxForums.com
What you noticed by using Live-View: "but when I use the screen images are brighter but blurred like the shutter is open longer??" is also typical
because the camera cannot meter proberly in Live-View. This is because normally in LV your K-70 and many other Pentax bodies meter with f4,0
but when the solenoid is stuck it meters fully closed down. So instead of f 4.0 your Pentax meters with f32 instead. The result must be...???
Very simple logic behind, isn't it?!
