Originally posted by Rob'O Hello everyone. I'm not sure how to explain this but I am having an issue with my K3ii. I have been using a third party wired release though now also have an OEM release, though the issue occurs without it. The thing I have going on is that after a period of time I can't fully depress the shutter button or the wired release button without having to activate it a second time to take a shot. It's as it seem that the camera 'goes to sleep' and needs to be woken up. I have reset the menus, tried all wired remotes and body shutters, cleaned lens and, body contacts and tried various lenses ( I use Sigma and Pentax). It happens whether a lens is attached or not and regardless of the lens attached. I know it's a long shot but I thought I'd ask the brains trusts within the group. I will attach a video showing what I mean. The first body is the K3ii and the second is the K5. The K5 was OK though now seems to do the same thing. It's ok until the bodies go into standby mode. You can see the K3ii gets 'woken up' (top LCD lights up) then the second press takes the shot whereas the K5 the shot is taken without delay. I hope it makes sense. TIA
From the short AVI I notice that the camera is not asleep. Before you push the button I see an F number and I see the ISO on the top LCD. It is definitely on, only the backlight is off. You push the button and then the backlight of the LCD goes on. If the camera was asleep, you would only see an empty lcd monitor with just some lines. The camera is in stand-by that is why the top lcd backlight is switched off. If it is in standby and you push the exposure button, the lightmeter and AF turns on and on the camera you have to push the button further down to expose. It seems that your wired release does it in exactly the same way as the camera does. First it switches the lightmeter and AF on and then you push further or again to expose. And you'll notice it works exactly the same on both camera's. It is not a camera problem, the problem is that you pause taking pictures and the camera switches to standby. I think that auto switch off is set to a long time or off.
