Here’s my lens testing/comparing regimen.
It doesn’t qualify for real quantitative results, but I think it tells me how my lenses perform at the edges and corners of field of view, as well as how sharp they are in the middle.
This is based on the (old - year 2000) ISO standard resolution test chart ISO 12233. You can buy a very nice version of this for more than $100 (!), or you can do something based on the efforts of Stephen Westin, which is more-or-less what I describe below. His version of the (old!) ISO chart can be found at
ISO 12233 Test Chart .
If you have a very high resolution printer (around 2400 dpi or so), you can just print out his chart and use it to fill the image frame of your camera. However, most of us don’t have a printer of that quality (and, you won't be testing at the highest resolution around the edges of the frame). Modern, low-end laser printers typically print at 600 dpi. Many ink jet printers claim a higher pixel density, but I don’t have much experience with them (but am rather skeptical that they really can print at claimed resolutions of 1200-1440 dpi).
I have taken a subsection of Westin's chart, which gives information on lines per frame height for the range from 500 to 2000 (the 5 to 20 scale), and blown it up to where it gives a reasonable printout with my equally venerable HP Laserjet 2100 printer, which actually prints at 1200 dpi.
Here is a link to my jpeg file which is at 2400 dpi:
http://photodave.us/ResTests/5-20-LinePairs-2400-137mm.jpg (if that ain't enough resolution there is also a 4800 dpi version!). If you open this file with e.g. Photoshop and print it at actual size, you should get an image which is about 137 mm long. Use the best printer resolution you can, and examine your printout closely to make sure that the finest details are adequately resolved. It should look like this:
Print out 9 of these at as high a resolution as you can, and paste them in the center and at the edges and in the corners of a piece of cardboard that is 18 x 32 inches in size. This size is critical if you want accurate results!!
Here’s what that looks like. I put a cross hairs target in the middle to help with focusing, as well as a color reference chart, and a length scale. (I made 3 of these for a photo course I taught, for the students to photograph so I could understand their cameras, hence the hand-written letter near the middle.) This is a low quality jpeg, so the resolution isn't as good as in the original.
Here's a 1-to-1 cut out of the top left corner, at full quality. This is with the SMC Pentax-D FA 100mm F2.8 Macro WR on my K-1, at f/8 . This combination readily resolves to much better than 2000 lines per height, all over my test chart.
Set up your camera (on a tripod!) at a distance from the chart so that the rectangle fills your camera image frame (generally across the frame for a standard DLSR 1.5:1 ratio). Then, the grid scales properly in lines/frame height. Take some effort to make sure that your camera is centered on, and orthogonal to, the test chart. Uniform illumination is nice, along with a proper color balance.
I take frames for just about every f-stop across the range of a given lens (use the Av mode and mirror lockup). For a zoom lens, you probably want to test at 3 to 5 focal lengths across the zoom range. Make sure to adjust the separation between the chart and the camera so the chart files the frame at all focal lengths. Feel free to check more focal lengths, especially if you have a favorite or two.
Then, just use your favorite image browser to look at the results, and see how many lines you can discern. I made a little table to print out where I write down the frame number and lens/focal length and f-stop and the limiting lines count for the center and all the edges and corners.
For modern sensors (say 15/16 Mpixel and up) and good lenses, you may find that you can resolve to 20(00) for almost all frames. If this is the case, you can always move the chart farther away - if you arrange things so that the chart fills only half the frame across (it's twice as far away), then all the chart numbers would be doubled - i.e. you could check lines from 1000 to 4000 per frame height.
Not only can you check your camera/lens resolution, but you will probably discover a host of other lens frailties, such as coma and chromatic aberration. The arrays of lines are quite unforgiving of such things! I usually just shoot jpegs for quick testing, but if you shoot RAW, you may be able to invoke lens corrections to see if they improve your results.
How do I get my inserted images to show without having to click on them?!?! Does it matter that they are not in a secure web site (i.e. not a https prefix?)
Looks like you need https! I put these in google photos and created an imbeddable link (what a PITA!), so now you can see my images directly.
