Site Supporter Join Date: Dec 2016 Location: Southeastern Michigan |
Well, the K-70 plus the most useful DA 18-135mm packaged together is the best bargain going, as I have said. And I am usually more favorable to going for a new vs. a used camera. That comparison link is good, but also far from the whole story. A lot depends on priorities. I don't use wi-fi to download photos. I don't even have a smart phone. I use a card reader- inexpensive, fast, and reliable. Easy to use. Plug in and play.
Of the K-70 advantages, the most practical are the articulating screen, and for those with little background, the SCENE sub-modes. I like the articulating screen for times when I need it for shooting from odd positions. Good for selfies too. But in reality, I don't use that feature on my K-S2 very often.
The K-5, like the KP, is an advanced or pro-style design, including superior construction, which means of course, omitting such an amateur-oriented feature as the SCENE modes. By employing this feature, a number of typical scenes are offered by scrolling through the menus to select the type of scene being dealt with at a given time, where the lighting is tricky and the results are not being delivered by the camera's usual automatic exposure settings. Snowy scenes, beach scenes, an outdoor night scene of a person against a night time background using flash, etc.etc. etc. This can be convenient, and instructive- ONLY if one takes notice of what settings the camera has chosen for each particular scene that is different from the usual settings. But even then, there is no explanation as to why. Once one learns what to do and why, it is far faster and easier to use the camera's excellent set of controls to change settings yourself, than it is to switch to the SCENE modes, then scroll through and select an appropriate scene. Furthermore, you can do fine adjustments on your own very easily for even better results, if the first shot is not satisfactory. Explaining what to do and why for such situations is one thing we do regularly here.
As to the SD card, right now in my K-5 IIs I have a SanDisc Extreme Pro 32GB with a write speed of 95 MB/sec.- super fast. Extra-fast write speed is mainly important for burst shooting at fast fps, which I try to avoid unless really necessary. I am not fond of screening through scads of images of essentially the same shot to see which one to keep and which ones to discard. If I did more of that, it would no doubt be a 64GB card. But the K-5 IIs is "only"a 16MP sensor design, yet it is an outstanding sensor, and this version can deliver fine imaging with exceptional fine detail with high-performing lenses , when set up for optimum performance. The 16MP design delivers smaller file sizes compared to a 24MP design, requiring less room on the SD card which will hold more images. The K-5IIs also has a deeper buffer than a K-70 for burst shooting along with the smaller file size and thus greater image capacity. So many more shots can be taken before the buffer will fill up and the shooting needs to stop to clear the buffer.
I do like the articulating screen and certain feature advantages of my similar K-S2. But there is really no comparison with my K-5 IIs as a photographer's camera. Even with the further advancements of the K-70, for me, if I were offered a free trade of a brand new one for my now rather old K-5IIs, (which has a quite low shutter count and is in pristine condition) and I had to live with only one or the other, there is no way I would make that trade.
Take a good look at the two cameras' pictures on the above link. It can be revealing. Look at the rear of both cameras. First thing to notice- more controls on the K-5 and they are spaced out much better. The thumb rest is much better designed, while the tiny thumb rest of the K-70 is situated so it would be easy to accidentally hit one of the buttons clustered around the ok button. Much more secure and effective holding. Then notice the AF button, on the K-5 is usable at any time for AF focusing without shooting instead of using the shutter button half press. On the K-70 this button does double duty with the AE-L button (locks exposure, which can be very useful at times) while each function has its own button on the K-5 IIs. Surrounding the K-5 AF button is a rotational switch to select the AF points and their operation: the camera's auto-select of all points, user-select (of any point among all points), or center-point only for spot AF. With the K-70 you must go to menus to select the AF points options.
Now go to the camera tops pictured. right away the top LCD screen of the K-5 stands out. You don't have to keep tilting the camera forward to view the settings and make changes. Of course, along with the better control layout, this requires more room and thus a larger body. Look at he shutter button, around which is the on/off switch, which also entails another function. On the K-70, there is also the video switch. That is instead on the mode dial of the K-5, while that spot on the power switch is taken by an optical DOF preview through the VF, a feature that is rather awkward to access via a menus with the K-70. This means, after an aperture is selected, (varying apertures will vary the DOF of a shot as well as affecting the incoming light), one can actually look through the lens by looking through the VF to see what will be or will not be sharp in the background when using a certain aperture, and do this instantly with the fingertip control! Of course, it also means while viewing, the aperture will be closed down to the value set for the shot which will likely darken the preview, but you can still see the DOF you will get.
Now look over to the mode dial. Both are set to the green auto mode. The mode not to use unless handing the camera to someone not familiar with the camera temporarily, so they will not make a mistake and accidentally activate one of the controls. Most controls will be de-activated. This is for the camera to make all the decisions-period. First thing for you- change to the"P" mode for fully automatic exposure shooting, still fully automatic, but will allow all your controls to be accessible. Notice around the mode dial of the K-5 is a rotational switch (hard to see in this picture) to select your metering type- normal segmented metering of entire frame, center-weighted, or spot metering (the light meter will only read the lighting off a narrow spot on which you train it to get a reading). You will eventually learn how to do spot metering when called for by certain tricky lighting situations that would throw off the usual metering. A very, very useful feature. With the K-70, changing metering type is done via menus.
If there were a left-side view offered, you'd see an AF mode switch. On the K-5, the settings are for AF-S (Single-shot where the shutter will not fire unless focus is achieved), AF-C (Continuous AF sometimes best for moving subjects), and MF (Manual focus). On the K-70, apparently just AF or MF, with the AF type in menus. On the KP, there is a button where repeated pushing will change AF types. The KP shares some of the same weaknesses of control features as the K-70, but some buttons can be programmed to make up for that to some degree, nor does it have a top LCD. But there are new controls on top for new features that atone for such shortcomings. And to be fair, the menus shortcut screen accessed via the info button of both the KP and the K-70 is pretty decent as a substitute for on-body dedicated controls, just not quite as fast and efficient. But the top-side controls of the KP are very special, and for me worth the loss of the LCD screen and dealing with some button programing.
If I had to live with just one, I would in this case trade off my K-5 IIs (with some reluctance) for a new KP, as it has done a convincing job of offering new, useful controls and features, while achieving a more compact and lighter premium body design, along with outstanding imaging quality.
This is not to detract from the value of the K-70. It is an outstanding value. Just to put it in perspective, and of course I am not too favorable towards buying used, unless a premium-built model and in top condition.
