The DA 18-55WR has its values mainly being cheap and still good enough. But it won't really get the most out of the K5II!
The advantage (to some, if needed is the WR).
It very much depends what you need.
One lens which is very underestimated but needs to be in really good condition, i.e. not wobbly!
But it is a larger lens for a reason. I had some contact to a person who serviced Pentax for decades, knew all lenses inside out.
He brought me to this lens and I never regreted it. He told me that the construction is similar to the FA31/1,8 and the K28/f2,0, i.e. a floating design.
It was developed by one of the japanese master-engineers of Pentax, I forgot his name.. but I remember he applied for a patent for this lens because it was the first and only zoom using this floating element design (a design invented by Zeiss and applied in their Distagon T* lenses)
- 16mm are very nice wide-angle for landscapes, almost 15mm and with excellent optical quality
- very nice close-up abilities (28cm and what I measured 1:3 macro at 45mm)
I personally don't like the DA-18-50WR
Good zoom lenses you can find from Sigma, the
Sigma 17-50/2,8 is supposed to be very good if it's a good sample, many like the 17-70 (17mm make a noticable difference to 18, and yet, 16mm are quite a bit more wide-angle).
The DA18-135WR is a very quiet zoom due to its DC Motor (as are Sigmas with the HSM motor). It has 1:4 Macro at 135mm but minimum focus distance is only 40mm.
The quiet but fast DC Motor can be an argument when you want to take photos of little ones, because they very quickly can react to the sound of the screw-drive mechanism. They hear the sound an change position.
My favourite Zoom is still the DA20-40 limited. It is DC, i.e. quiet, amazing built quality, almost as good as 3 prime built into one lens.
The
forum test ranked it higher than the legendary FA31 (which I don't fully agree with) but you have the DA21/DA35/DA30 in one go but without the macro qualities of the DA35/2,8macro limited.
It very much depends on how much you can or are willing to spend.
If a DA20-40 is possible, you won't lose money with it!
A DA16-45, allthough a bit bulky, is almost as good and very cheap. But do consider the size and get only a really good sample.
I know a famous photographer who uses it with his K70 and KP and is thrilled, he never really considered it before.
A cheap and yet better lens than the Kit 18-55WR is the Sigma 18-50/2,8. But again, a bit larger.
Important to know if you buy a Sigma with inbuilt OS (antishake): The OS draws enery, i.e. the battery empties quicker! Even if the OS is switched off!!! That one must know.
Also you don't want to use the OS together with the Pentax antishake! One or the other!
Hope now your head is not spinning more...
This is the difficulty of receiving many well meant opinions.
And they are well meant!
