Originally posted by AstroDave I am reluctant to try turning it any harder without some encouragement here. The feel is certainly like something is stuck mechanically. There is basically no play in the dial.Any ideas? Thanks.
I just tried two of my ME Supers, without lens or battery.
The exposure mode dial locks in position in "Auto", at which setting the white button is in a full-out, proud position (i.e., not depressed).
The white button must be pushed to unlock and rotate the exposure mode dial from Auto to "L" or the other settings. At the non-Auto settings, the white button remains depressed, flush with its surrounding bezel.
The exposure mode dial may be turned from L without needing to push the white button. The mode dial may be rotated with a gentle torque, i.e., no need to go hard on it. There's a
slight resistance at first.
Sounds like yours may have a mechanical issue. Upon cursory inspection, I couldn't figure out what might be binding.
Edit: You say that the white button is "part way in." At the L setting, the top of the button should be flush. Try wiggling the mode dial while pressing the button with a toothpick or other tool.
Edit 2. Sorry, can't resist a bit of dark humour. I was thinking, If all else fails, come on to that sucker with 12-inch slip-joint pliers and apply some manly torque just like tightening a truck wheel lug nut. But I digress. That's not the way to fix cameras.
- Craig
