Originally posted by Gilles T Hello Tim,
Thank you for your answer, unfortunatly my difficulty is the front part with 4 lens, and it's not present in this vidéo.
Gilles T
Okay. Did you scroll down to post #4 in that thread? Is that helpful?
Anyway, I'll recap here what I know about my own Super Takumar 200.
With my lens, using a dish washing rubber glove for grip, the top end simply unscrewed from the barrel. If your top end is stuck, try heating it with a hair dryer. The top piece on my lens has two elements.
I'd think the name ring should unscrew if you have a friction tool of the correct size. I usually use a scrap of rubber glove and the open end of a bottle or jar. And the second element appears to be held in place by a slotted retaining ring. You'll need a lens spanner to loosen that.
The next group is now exposed and should also unscrew from the barrel. It has two elements which appear to be held in place by retaining rings. I presume the retainers are threaded and should unscrew if needed. Again, try heat if the parts are stuck. And if you need a solvent for glue or cement, try a few drops of isopropyl alcohol.
Here's my lens apart. The second photo shows the retaining ring of the second element with the spanner slots circled.
Edit: Oh, I see from your photo you may already have discovered what I've just told you?
I've never completely disassembled the front groups, but if you have any more questions, I'll try to help.
